Washer nozzle and tube routing / wiper switch
Kitsap
Anyone know if these are factory windshield washer nozzles? I’m thinking no but can’t seem to find any online. I have a washer fluid tank/pump that comes with the tubing, just not sure how it routes in the engine bay with the dual nozzles.
Looks like the ones that were on a 1970 hood I had. I think they were stock one early 40's then the switched to the plastic ET head looking ones.
I can find posts for later years where it routs through the windshield frame but I’ve searched here and the google and come up with nothing.
Yes
just under the lip of the cowel
inside the engine bay
remember this was a dealer installed assy option
and routing had to be quick fast and efficient
so surface runs tucked up with the vacuum tube
For the t-case etc makes logical sence to me
Modern Toyota’s are run in a similar fassion
the exact placement of that 1 clip is a critical clue
note my cataloger says only 1 per Vehical
See if u still have the Clip installed
Maybe it’s wedged in time and space right before our eyes
And only a sharp one will find it ...
I will continue the hunt
And post any relevant info
got. Buddy in Texas with a. 12 truck fleet of all
Older gems
I bet he has our concrete TEq facts ....
That’s very helpful. So the tubing rides in these?View attachment 2285287View attachment 2285290
hey Tubster
if u like i can send out a few of the multi use clamps i showed above to help you out ?
NO Cost involved ...........
i also have mY Version and brand of Reproduction OEM Blue tint hose , just tell me how long u need
i have a large Roll as in many meters ...............
Well I knew I needed to replace the wiper switch because it wouldn’t turn the pump on. Changed it, pump up works but I’m still having the same problem that the wipers will not turn off every time. It was fine when I had the 40 off but switched on, started the engine and they won’t turn off now unless I park them between off and the first speed on the switch. Could it be the motor? I’m not very good with wiring and it’s a pain to get up in there (fat).
Well got the tubing in. One nozzle was clogged so I blew it out with compressed air. I got washer fluid now. Took the switch out a couple times and now it seems to be working. Hardest part was getting the defrost duct back in afterwards.
