I bought a 1977 a year ago and in the process of working on it - I have a question and I'm sure I can get an answer here. How do you get the washer fluid to work? I'm not sure if the pump is bad or not. When I pull the wiper knob it just moves the wipers. It seems to have to wiper speeds, but no fluid comes out when I pull it out all the way -
Looking for some info
Thanks
Thanks
LOL! And if that doesn't work, check the pump in your reservoir. If the motor hums when you bump the switch but you're still not getting any fluid, the blades in the pump may be shot like mine were. I installed an aftermarket pump farther up the line and called it good...
