Washer bottle outside engine compartment
Have you ever driven a vehicle that has been sitting in 0 degree temperature?
Yep.
Stick shift too. But, that was many moons ago.
Now I just really don't care about the car or the engine. If it doesn't make it to 336,000 miles and only makes to 279,000 mile so be it.
Yep.
I'll err on the side of caution. I don't plan on getting rid of my 80s anytime soon.
My solution was to use the space in front of the battery. I picked up another stock radiator overflow bottle and bracket, and radiator overflow hose that's long with a 180 bend on the end from a mid-2000s Mitsubishi Montero Sport, and moved the overflow to the other side of the radiator. Plumbed the pump and lines into the bottle in the original position. Worked slick. I did about 5 years ago, no problems since.
I'm also one to use the washer. That would suck to go without.
Nothing wrong with 5 mins of idle time in the morning before driving. I've lived in extreme climates where -40 was normal for weeks at a time. Don't pretend that you wouldn't warm your rig up if you were in this situation too. Because I wouldn't believe you anyway.
I picked up the washer bottle and bladder out of a 92 at the junk yard.
I removed my charcoal canister and put an inline fuel filter in place.
@LS1FJ40, So you have no charcoal canister and are just venting to atmosphere? I am stuck between venting to atmosphere, venting to the air cleaner area, or venting to the intake manifold.
Well, I was going to. Now I'm not sure. I installed an inline fuel filter which basically sends the fumes from the gas tank to the manifold. I'm starting to second guess myself.
Anyone have any input on this. Haven't really seen where anyone did this...
So this is what I did. I haven't started it since I did it. I'm just wondering if it will work now. The "tank" line is going in to the filter and the "purge" line is coming out of it...
Anyone have thoughts?
So you're just sending the fumes right into the VCV (or equivalent on the 1FZ). I don't guess there's anything wrong with that, but what is the fuel filter for exactly?
I want to take the VCV out of mine (since with a disabled EGR there is no activity to the VCV)
I removed my EGR so my VCV isn't doing anything either...
I suppose the fuel filter doesn't do anything then...
So, this won't hurt anything. Correct? Like my motor won't blow up?
It's not the motor blowing up that worries me.
Any sort of back fire into the intake manifold might conceivably propagate back into the fuel tank. While highly unlikely, the consequences would be severe.
Ok. So the option is to put a filter on the tank line and cap the purge line coming off the VCV then...
As you said, highly unlikely... Like .0001% chance. you would need to have the right Fuel Air mixture in the tank and lines at the same time of a pretty sever backfire. Would be tough to actually attempt to make that happen.
Snapping the throttle open and closed can cause air to be sucked back and forth between the manifold and the tank, quickly bringing the mixture to a combustible range. If anyone still has their EGR in place, a cinder of burning carbon deposit could find its way to the manifold very easily.
Even a minor chance becomes a concern when the outcome is you and/or your family perishing in a hellish inferno.
With that said, I think venting to the air cleaner makes a lot more sense than the manifold. Less vacuum and way farther from anything that burns. If you have a snorkel it would even serve as a chimney to vent the fumes up higher!
Wouldn't venting it to the air cleaner then suck it in to the intake?
Yes, but a backfire making it all the way from the intake to the air cleaner would be less likely in my opinion.
I'm not trying to crap on your implementation, I'm just expressing the concerns I had with removing my charcoal canister.
FWIW, I have a 1988 RN50 with the vent from the gas tank open in the engine bay. :meh:
