Warning lights still there...help.
Minnesota
help.
OEM belts can only go on one way. It's possible that your new alt is bad, but the law of averages points to another problem within the charging circuit. Possibly bad cables/corroded connections between the alt/fusible links/battery. I would assume you went over these connection points closely while replacing batteries and alternators, but it sounds like you need to spend some quality time with the FSM and a meter. The FSM gives step by step instructions, where and how to check, etc.
I will spend more time looking at the FSM and do some more quality trouble shooting.
Question 1: I'm using Gates belts. Could that be the problem? I wouldn't think so, but just curious.
Question2: On the fan pulley, do both slots get used?
Does my belt locations look okay?
Correct. Inner pulley of water pump and inner pulley of alternator get driven by the middle pulley of crank. Outer crank pulley drives PS pump, smog pump, and slightly rides in the outer pulley of alternator as a guide.
Gates makes good belts. I doubt that's the problem. I assume you've checked tension on the main alternator belt.
Update.
Now,
My charging system seems to be working. I get about a 13.8 volts reading without any accessories running. With the headlights and others on, it drops a little.
The warning lights no longer come on, but it still hesitates a little bit at complete stops.
Was it that I didn't wait long enough? Is there a break in period?
We'll see about today. I'll see if the readings are still the same.
I will update more later.
Thanks.
lispeej
Alternators do not break in. Either your battery was very low and the new alternator finally charged it up or you have a bad wire/connection (as previously mentioned) that decided to work correctly. If the voltage just came up to 13+ overnight, then it would point to a bad wire. Check your wires by finding where it starts and terminates. Put your voltage meter on each end and see if there is a voltage drop between the two points. More than .5 volts would be concern. Should be real low on short wire runs.
There are 3 fuse links that are right off the battery + terminal. The charge/dis-charge current goes thru the MAIN fuse link. Check these fuse links for kinks and burns in the wire(s) and corrosion of terminals. Fuse links are cheap and replacing them good insurance. Worn out fuse links a major electrical PITA on these trucks.
Off the negative battery post is a black ~#10 wire that connects to the left fender; check this for corrosion. Check the grounding strap at the rear of the engine to the firewall.
Now,
That is low. It should be 14 and change across the battery terminals with the motor running. Motor off should drop to 12.8 or so.
I am currently running at 14.01 when egine is on, and 12.75 or so with engine off.
I did look at the fusible links. The reading off them are a bit different. At one of the link, I had a 13.99. Are they easily replaced? I might consider doing them for extra insurance.
I do agree that maybe my battery had to be charged up to normal. Maybe afterall, my alternator is good. Has anyone done these fusible links before?
Thanks for all the recommendations so far. Every little bit help.
Put your battery on a trickle charge overnight or take it somewhere that can do a quick charge.
-B-
