Is a Warn Mod# 8274 Ct5 big enough for my 1991 LC?
The 8074/8274 is more than up to the task of hauling a cruiser out. It doesn't stall at 8000 lbs - it pulls 8000 lbs. double lining is easy since it has 150ft of cable so even if you need to double line, you have lot's of cable to do this.
How much does your 80 weigh? Normally a 8000 lb winch is a bit undersized for an 80 with many going for a 9 or 10,000 lb winch. With that being said the 8274 is a very nice winch and you can always use a block/pulley to double your pull from 8,000 to 16,000 lbs. If you do this I suggest carrying a line extension.
I'm not trying to be a smart ass but a double line does not double your pull. it just halves the amp draw with the result that the motor can run a little easier and there is less pressure on the battery.
Really? I'm not trying to be a smartass either, but let's go back to elementary school physics and the use of simple machines.
Fileulley1.svg - Wikipedia, the free encyclopedia
Not sure that proves your point... the way I look at this picture is that the weight (W) is evenly distributed at the two ends. That is, 1/2 of the W is supported by each arm around the pulley (W/2 and W/2)...
Wait a minute... after thinking about this a bit more - I believe you're right: by applying a pulling force of 8000Lb on one end of the pulley, the other end of the pulley will also exert the force of 8000lb resulting in 16000lb of force in the center... makes sense to my simple mind.
I wouldn't put less than a 12K on an 80 Series, but that's the way I roll....
Mike54 said:I'm not trying to be a smart ass but a double line does not double your pull. it just halves the amp draw with the result that the motor can run a little easier and there is less pressure on the battery.
