Warn hub install question
Boise, Idaho
Howdy all. Recently purchased a set of hubs from the classifieds and the new gaskets for these hubs showed up yesterday so I decided to pop them on last night in the driveway. Pretty darn easy, the worst part being how they look.
From my reading, having a 92 means I have the shorter birfs. I was told by the seller these hubs would mount right up.
My opinion is that they do NOT mount right up, but maybe I'm doing something wrong. I'm hoping for some guidance here.
See below:
Snap ring was on the axle just fine during disassembly:
New gasket going on. Was surprised no gasket was on there before??
Hub installed. Now the problem begins. I assume there should be some kind of retainer (especially since the instructions I found online says there should be) but the birf is too short. The instructions also say if the axle is too short, use the retainer. I can easily make said retainer, I'm just wondering if I need to make it so the birf and sleeve are tight to each other or if there should be some end play there? Also, the picture looks ugly, but that grease looks/feels pretty nice.
What I'm talking about is the little stepped washer inside the blue circle here:
TL;DR: does the birf need some end play? Or should/can it be tight to the hub. Need this info for dimensioning the retainer I'll be making.
Thanks!
On mobile, can't delete this photo??
Some Warn hubs use a bolt and washer in place of the snap ring. With the birf pulled fully out, is it flush with the hub gear, or does it need a step washer?
Your instructions say "Toyota Only 1976-1985", so minitruck axles. Is there any difference between minitruck axles and 80 series that could be causing your issues?
Can you thread a bolt into the axle end and pull it towards you enough to clear?
It will need a step washer (I will turn on lathe today). That leads to my question of does the axle need a little end play or should it be tight to the driving hub. A little research has led me to believe the axle needs a little end play for CV alignments sake.
The last picture (double posted, can't delete for some reason) shows where the axle is when pulled all the way out. It will require making a stepped washer/retainer. I'm just wondering if that stepped washer/retainer needs to allow for some end play in the birf, and have received some info that it does in fact need some end play.
Shouldn't matter. The drive spline isn't a sliding spline, when engaged. At least it better not be...
... A little research has led me to believe the axle needs a little end play for CV alignments sake.
Correct, mainly for the bushing, grease. It's not critical, I would guess .010-025" ish, but have seen many with more, without issue. If tight, will wear the bushing till it has play.
Isn't that known as a self-limiting solution?
For what it's worth, I've run the step washer in warn premium hubs for 7 years and wheeled hard with no problems (full time, PO didn't finish part time conversion). I took them off to run gun drilled, grease-able birfs and no visible wear on hubs or spindle bushing (the step in the washer appears to let grease out of the spindle, i.e. a little end play). The washer and bolt were snug on axle, not spindle end.
I should add even though I have a 93 the birfs I replaced were the longer 95-97 stub shaft.
