bull said:Looking good spressomon!
Can you measure how much room you have between the inside of the frame rail to the winch on each side?
Also measure the distance from the back of the winch to the radiator area?
Test test..this thing on?
spressomon said:The distance between the TJM frame plate mounts is 29.5". This width is not effective with my bumper since the TJM winch adapter plate needs to be supported on the outside corners...which, because of these two brackets, reduce the overall useable width. The frame crossmember, which supports the radiator, is only 1" farther back than the top of the winch drum cross-supports.
89s rule said:Why would you want to? I am just not sure if this bumper or the ARB saharah? give enough protection. The main reason of ours is to protect from deer! Same will be the case with our new car.
Kneel said:Is that "little" 9.5 gonna be enough to move that rig when/if you need to? If you're in a position where you have to straight pull with 20cu/yds of mud or sand under a +6000lb rig, that is approaching the upper capacity of that winch. I've seen plenty of older planetary Warns go up in smoke with less of a load. I have reservations about the M12000 being enough for my rig when it's finished. It's better to have too much than not enough in that situation.
calamaridog said:I want that model bumper but I hate the shiny bling. If I can unbolt it, I can powdercoat or something?
We don't hit many deer here in San Diego![]()
Kneel said:I'm sure you're right. From what I hear, the new Warns are a far cry from the old planetary smokers. Personally I've seen one too many W9000s and W8000s take a dump to buy anything other than Superwinch. I have an X9 and a Husky10 on the 90 and Disco respectively for almost the last 10 years. Even the X9, with not being serviced as much as it should be, just keeps pulling. Slowly, but keeps pulling. Not that I'm bashing Warn. I've seen the 8274, M12000, and M15000 work all day and barely get warm. Much respect for those as they've saved my behind plenty of times.
89srule the ARB bar is airbag compliant.89s rule said:I understand the no deer in SD. But they can help in auto accidents as well. Only thing I am still a little unsure about is that the t-15 is not air bag compliant.
How strong is the Sahara or T-3C TJM vs. the regular ARB or the t-15 TJM?
Keep up the good work!
calamaridog said:Kneel,
I'm sure Spresso has a snatch block and understands mechanical advantage
Heck, he could do a triple line pull with two snatch blocks...
Right?
moooooooo said:89srule the ARB bar is airbag compliant.
i've got some hopefully better quality images of my deluxe bar attached which might give you an idea of colour coding, although i had to compress them a bit
cheers
peter
89s rule said:Peter,
Thanks for those pics, that looks very nice. Did you have to get that painted yourself somewhere? Which ARB model is that? And what issues/non-issues would airbag compliant vs. non-complaint? Is it just paying for the testing or?
Kneel said:Just remember to get stuck in a convienient location with a short recovery distance where you can hook a single block to, let alone 2 or 3... ;p
cheers
peter
The bar vibrates, but no more than expected. I actually just got back from a drive on some logging tracks only a couple of hours ago and i had the driving/spot lights on as it's getting dark earlier here as we get closer to winter.dclee said:Moooooooo...oooooooo -
Do you find with the weight of the winch that the bar vibrates any more on corrugated tracks? I'm concerned because the deluxe bar has the winch cradle built on the front of the bumper (like the 80 Series bars) and is not attached directly to the frame, like on the TJMs or even some of the standard ARB bars for the 100 Series.
Thanks,
