Just a heads up, and for future reference, I ended up needing to modify the walker crossover pipe. Still not sure if I got a pipe with bad bends or if the Dorman Chinese repro Ram’s horns are just poorly formed - but I did have some trouble getting the two to match up.
In the end I welded about an extra 2” into the downpipe, which changed the bends for a better fit, and ditched the heat riser spacer.
This got me a bit more clearance with the oil pan (about 3/4”) and lined it up with my exhaust manifolds.
Another issue, if you plan to wheel it, is front driveshaft clearance:
Under flex on stock springs, I’m contacting the y-pipe with my front driveshaft. In asking around I’ve discovered I’m not the only one with this issue either. I’ll probably add a lift and lower the bump stops to try and avoid this in the future, until such a time I can replace it. For now, it still runs and does the trick.
