Wagon stuff 80,100,60,55 and a few 40 items
MH, IDaho
What kind of drop mounts used for the 80 series front sway bar? Are they something like 1"x2" square tube, or solid metal?
Do you have the factory 100 series roof rack bars? the ones that run the length of the roof? if so shipping to 30019
Thanks
They are the actual factory mounts to the frame. I might have a set of spacers laying around somewhere if that is what you are after.
You have a PM on the PS rear flare. Thanks!
Do you know when the birfield length changed? If your 6/94 is the same as the 97, I'll take it. Do you have inner axles? Especially the short side?
Ben,
they are cloth and manual.
Andy,
I'm not sure if this birf will work in a 97. I can measure the splines. I don't suppose you have a late model one to compare measurements on. I may have a set of inner and outer axles available soon. I have a complete front axle I've been sort of saving that might be on the chopping block soon.
Ben,
Andy,
None to check the sizing. I'd love a spare set of inners and a spare birf. In our little group, the spare shortside front and spare birf, got "consumed" on Dusy Ershim last summer. I would like a full set of axle spares prior to Moab this year.
Andy,
SOR.com shows the change was in 8/92. I did a search here and came up with nothing definitive. So I'm thinking it would work in a 97. The axles are out of an unlocked axle if that matters. I suppose being able to drive in 3 wheel drive instead of rear wheel drive would be better than nothing on the trail (thinking of those with elockers).
Andy,
The 8/92 was the availability of ABS. The 93s for sure had a shorter spline section, and a shorter drive flange. Some of the 94s did too.
I don't care about the e-locker stuff, I have ARBs
Got any knuckles?
The only knuckles I have left are non ABS. Which would get you off the trail, but you'd still be searching for parts when you got home.
I'll PM Cruiser Dan to ask him how to identify the spline section. I do know that they were too long to run Aisin Hubs on without a shim. I'm thinking the early ones you could run the Aisin hubs on without a shim. I know the 91/92 birfs you could run Aisins with no shims.
I'm interested in the 80's driver's door, shipping to 33014?
It is going to take me awhile to calculate shipping on the door. I'll have to load it up and run it into town to get it weighed and measured. I should have a result back by Wed. noon.
OK Ben, I'll put your name on it. I'm not going to be able to ship until Wed. lunch if you need the switch ASAP.
Ah, I might know somebody coming through Sunday. I'll check with him tonight. Just missed a chance with Eric K. going down for the game two weeks ago.
Ok, i'm in no rush, unless shipping is totally unreasonable i'll take it for sure
Sold the hitch yet? I assume it will fit a 97 lx no problem?
