vsc trac/ vsc off/ vgrs lights on
Hey everyone, I changed the bulbs in my cluster (only bottom 4 in a row able to change) after putting it all back together, I got the VSC/TRAc light on. Cheching the Techstream got a code - C1340 “Open circuit in center differential lock signal (during center differential lock ON).
Any ideas?
Thanks.
Any ideas?
Thanks.
I just pulled the same codes after finally getting Techstream to work on my computer. After some searching it looks like others have reported the same issue and fixing it by replacing the center diff lock sensor. Read through this thread and the two that are linked in it to find the Beck Arnley aftermarket replacement:
My C1340 VSC TRAC OFF Lights Fix
Any ideas?
Thanks.
Ok, so I ended up going back to tho original bulbs and problem solved. So much for LEDs in my cluster. 😠
2006 lx470. I was having immobilizer issues and Toyota dealer Identified a short in the harness and repaired it. No more immobilizer issues But now I’m having every symptom that Paddo lists in post number three. ECU B-2 fuse and my truck appears to be a 30 amp in the engine compartment. It’s good but replaced it anyway. No improvement. Headed back to the dealer tomorrow and preparing myself for them to tell me the ECU is bad and it’s not their fault.At which point I’m going to quit using this dealer even if the ECU is bad and it’s not really their fault. Any thoughts or suggestions?
