VSC Coming on Intermittently
Reviving this thread for noting my own issue. I’m getting activation of vsc on curves which started AFTER replacing my steering rack with an OEM Toyota rack.
Going to start with ZPC. Any further tips on order I should go through would be greatly appreciated
Make sure you don't have any play in wheel bearings. There shouldn't be any.
This is extreme wheel bearing play.
Also check ball joint. You shouldn't have any play.
Also check you upper ball joints and TRE.
Did you ever figure out a fix for this? Had new torsion bars put in due to adding a new front bumper on 2001 LX470. Replaced wheel bearings due to play. But activation still happening on curves. No codes showing. Could it be the Yaw sensor? or is it more likely a speed sensor? Thanks in advance!
