Vortec Fuel System Problems
"the whale's vagina", CA
Having some itermitent fuel problems on my 99 vortec engine. Truck is an FJ40. Could not get it started all day. Checked the fuel pressure at the poppet on the fuel line in the engine bay. When my wife was in the drivers seat I had her turn it to the first click to prime the pump. 40psi. Had her crank the engine, about 40psi. When cranking at one point the psi jumped from 40 to like 65psi, then back quickly to 40. Let it sit for awhile, threw some tools at the cat and then tried it again. Primed it and the guage was set at 60. cranked it, took awhile but it started. Checked the pressure, stayed pretty even at 53psi while running, idled it up to 2k, 53 psi.
Pump during priming sound pretty bad. I am running an electric, E2000, think it is from a ford truck? Louder than usual, somewhat grinding sound. The pump must be bad? Has anyone had a pump go out on them like this before? Does it usually go out gradually like this or all at once? Just want to make sure I am fixing the right thing if I am going to take everything apart.
Also wondering what the appropriate fuel pressure is during the priming period (key one click and pressure building) and during running. I think I remember it should be 65psi at prime and 65 psi during running. What do other have on a consistent basis as far as fuel pressure.
Thanks,
Noah
Noah how do you have the pump wired? I have been doing some reading as I am planning on a tpi swap soon and one of the things mentioned is to make sure that you run heavier wire directly to the pump and use a relay to set it off. This ensures proper voltage and amps to run the pump at the right pressure.
I had a pump fail on my TBI setup in a similar fashion. Would drive down the road in the truck would just fade out. Finally it just flat quit on the side of the road. OTOH my folks have pumps on the multi-port injection systems (like what the Vortec is) just flat stop. As in they drive to somewhere with no issue then try to restart and get nothing. Drop tank, replace pump and return to driving like normal.
Sounds like you found your problem is the wiring and connections are good otherwise.
Nick
Noah...this is a common symptom of having a restricted flow to the inlet side of the pump. My guess is that you have some gas tank crap stuck in the low pressure fuel line. Pull that line off the end of the pump and check the flow.
I had this happen to a friend of mine . His pump went bad because he had no filters before the pump .He and I now both use two high flow filters inline before the pump and havent had any problems since.( both are vortecs)
I have prefilters installed before the electric fuel pump. I was having problems with the front tank 2 weekend ago on the trail. Switched to the rear tank and drove home fine. Turns out after inspection that the prefilter was severely clogged, I used too small of a filter. Drained front tank, Replaced both prefilters. Gassed up both tanks. Tried to start and only getting 40psi. I pulled the lines out of the intake and ran the pump continuous for awhile, pump seemed to be pushing fuel fine. Reinstalled everything. cranked the engine and checke pressure, still getting 40psi. Then it jumped while cranking up to 60 and back down to 40. Let it sit for awhile and now it primes the pump at 60 and starts, runs psi at 55. I can get it running now but my questions now is whether I should replace the pump for good measure as it may be going out or could a pocket of air in the pump/fuel line caused these symptoms? I am thinking that the system might of had major air in the lines due to the sucking on the front tank and getting no fuel as the front tank filter was clogged very badly. Thanks for everyone's help and opinions and excuse the babbling rant....
