I recently fininshed my '73 fj40 with a '97 vortec. I have been test driving it short and long distances on the roads before I take an extended off raod trip. I have run into a very intermittent problem. The engine harness is new (howell) and the body harness is all new - not an old wire in the whole rig. It has been running absolutly perfectly 99.9% of the time. here is the histpory on the issue: After a long two hour test drive, where I had shut it off about half way through and it restarted fine, I parked it the garage and about 5 minutes later I wanted to start it hot again to see if all was good. It would not start and the alternator light was on. just would crank but no starting. I went inside pissed off to think about what it could be. After 10 mintues went out and it started fine?? It has then run perfect for 2 - 3 weeks. THis week I drove it to work 3 times anf on the way home Friday I was going along the highway at about 70 mph and all of the sudden the engine shut off and the alternator light came on. I pulled over and tried to start it with no luck just cranked like the last time. I popped the hood and was cheking a couple of fuses and saw nothing wrong. After about 5 minutes I just decided to try it agian and it started fine?? It ran great the rest of the way home and I even stopped and shut it down for an hour and it started fine etc. I am scared of a short somewhere but Like I said I just did all of the wiring and was extremely careful not to have any wires exposed etc. Can you guys think of any other causes? Possible an alternator issue? Let me know your thoughts. Also, no check engine light came on.
Greg
Greg
