Vortec 5.3 Or 5.7
NE ALABAMA
Whats the perferred Vortec Engine? The Vortec 5.3 Or 5.7? I plan on swapping a Vortec into my fj40 (1 ton trail rig) and have found both engines (complete fully dressed W/ harness & computer) for the same price. Im not sure which would be the best choice. Also what manual trans are you all running?? Thanks for any help...
If you plan on running an older manual tranny (e.g., SM420 or SM 465) you will have to choose the 5.7 (GEN II) engine, or spend $$ on the AA bellhousing adapter kit for the 5.3L.
IMO, if you go with the 5.3, take the tranny that's attached now...will make the conversion mucho easier on you....
The 5.3 is a more powerfull motor from the factory too. None of the 5.3s have distributors either which I see as being a problem with a lot of engine swaps. Of course the 5.7 you are looking at may be distributorless as well.
The 5.3 is still in the pickup. It's a '02 2wheel drive w/ an automatic. If I use the auto v/s a manual, Im not sure of my advantages/disadvantages. Maybe I should research & consider it.
