Voltage drop or something else?
Amsterdam, The Netherlands
Hey all! I’m a new member to the forum, but a very happy ‘user’ already for some time. This is the first time I cannot find a solution here so this is my first post! :)
We’re traveling with our 2004 Land Cruiser 105 GXR from Amsterdam to South Africa. Made it to Namibia already but we’re facing some weird issues with the temp gauge.
Lately we see the temperature gauge increasing to just over 3/4 and dropping again. All smoothly and within like 20 seconds total. Happens not often, just a couple of times on a long driving day. Some days nothing. Driving conditions are generally smooth.
Today we noticed that the voltage indicator drops to around 12v at the same time. Settles back to normal after. Probably related?
Our radiator, vicious clutch, thermostat, alternator, water pump and batteries are all new (<2 years).
Main earth ground on engine seems good. But maybe worth another check. I’m hoping it’s not the small mini wires somewhere behind the dash. Btw the oil sensor has been bad for over a year (like they all do…) so not related I assume. Oil levels are good!
Does anyone have a clue on what to check next?
Many thanks for your help! Very much appreciated :)
If it was a 100 series w/4.7L 2UZ. I'd suspect belt slippage, due to weak fan belt tensioner.
I'd also be aware if timing, related to water (rain). Which could also point to belt slippage, or water entry into cabin (junction boxes or wiring).
so jealous of the adventure you are on right now. and even more of the gold Toyota emblem on the hood lol. But the swing out rear door , not jealous lol
Does it have the 2uz like suggested above?
What about getting a scanner hooked up so you can monitor real time voltage + engine coolant temperatures. If I was in your shoes I think that would be the next thing I check.
>> Along with making sure coolant is topped off, after full engine cool down 8+ hours, in reservoir and radiator. Tight / clean battery connections + all grounds, if 2UZ you have 3 grounds under the hood .
>> Is this the first time the problem has happened since the work done 2 years ago? Made it all the way to Nambia with no issues and now seeing issues?
Do some detective work and try to make sense of what has changed between working condition and current condition , might clue you in to what's wrong
Thanks Mike!
It’s the 1HZ. We have the barn doors, which I actually really like! We have a bit of a camper interior in the back which goes well with the doors haha.
I have some new intel as of yesterday; it really seems that it’s an electronic issue because when the temperature was spiking again, I stopped and felt the radiator hoses, which were ok to touch for a couple of second. I compared with a friend with a LC100 who is joining us for this week and the temperature is the same.
Another clue was that after I started the engine again, the temperature was normal and the sub tank sensor was back at around full instead of at 3/4 full. This happened earlier.
I cleaned the battery connections, cleaned the earth (4x) to the side fenders and check whether the two grounds to the engine were connected well. Doesn’t make a difference. Batteries are at around 14v when idling (though the gauge says a bit below).
So I’m assuming that something (before?) the instrument cluster is causing a voltage drop (not always, but sometimes) which sometimes goes through the temp gauge, and sometimes the fuel gauge.
Maybe it’s a short circuit which causes the troubles. The thing is that nothing has changed in the wiring etc.
The annoying thing is that it doesn’t happen all the time. Some days or for many hours nothing happens and when it does it’s just briefly.
Probably difficult for you all to help diagnose but I wanted to give it a try. Probably have to visit a car electrician in Windhoek soon.
Thanks all!!
