Viscous coupler gone! Yes.
Well, that's completely wrong. There's no 'percentage' (not Beo's word, but mentioned by other posters, i.e: 80/20, 60/40, 50/50 et al) at all. It's a differential.
I know it's a differential Spike. Read what I said again. I was discussing the transfer case and you interpreted that as meaning only the differential. I guess you didn't know that the transfer case includes the center diff and the limited slip VC and the design of the transfer case transfers the torque by some percentage when there is slippage in the front or the rear by using the VC.
Your water line analogy only works if you talk about a differential by itself. The whole point of this discussion (unless I'm in the wrong thread...) is the pros/cons of the viscous coupler in the transfer case.
"When a rotational difference is created between the front and rear wheels due to slippage, torque is transmitted by the visous coupling from the high-speed wheels to the low-speed wheels, thus reducing the rotational difference. As a result, optimal torque is transmitted constantly to the wheels."
(Toyota's words, not mine.)
-B-
Right right right.....sorry about the total brain fart. Got it! Thanks guys. This kind of makes me wish I could put a TC from a 4Runner or Taco or Tundra in my Cruiser just to save the wear on the birfs.
You've been here over two years and don't know there's a relatively simple conversion kit available if you want to go that route?
Yes, you can drive your LC without a viscous coupler. Just don't loose traction to ANY wheel, or you'll be dead in the water.
Yeah, in theory....
But really...
1) How many 91-92s have you seen "dead in the water"? All 80 series (91-97) with the center diff. open are exceptional in situations like packed snow or gravel roads. The diff's just seem to do an excellent job of power distribution.
2) Isn't it correct that even a 93-97 will make little or no forward progress if you remove the front driveshaft and don't lock the center diff?? That VC just really doesn't seem to do much (except seize and cause problems).
Curtis
Good info. The part time kit forces all of the power to go to the rear DS until the CDL button is pressed. At that time, front and rear DS receives power 50/50.
DANG! Sorry wrong again!
100/100 IN 4WD, 100% to the rear in 2WD.
Listen to me, when you reach down in a Hilux and pull that lever, all it does is engage that front shaft. (LIKE A PTOOOOoooooo!! :mad:) It has not altered the % of torque. If you install a PT kit into an 80.....the CDL switch has now became the lever, the TC has been altered to a PT and its shift linkage (CDL switch) just performs a different task.
If the front or rear diff has no traction that diff DOES still have 100% of the engines power. Say your on your concrete driveway and you back off into grass pulling something with your 4WD, as soon as your rear wheels looses trac, your front still has 100% of what the engine can offer, (only the full load is now on more fragile parts and it will most likely break)
Truth be told 50/50 is more like what an 80 has riding around with the CDL unlocked...
this has a center diff, a VC....
YouTube - Jeremy Clarkson Lamborghini Gallardo vs. Ferrari F430
(I could be wrong though it depends on the definition of torque split and how it is calculated)
Curtis
The way I understand it, a VC has to have a torque differential to operate. So, if the drive shaft is pulled, there is no torque differential as I understand it. (Because, in reality, even on wet ice there is some amount of torque going to the front wheels, but in the case of a pulled drive shaft there is no power transfer, just spinning flange. I think that's why the VC doesn't lock up properly with the drive shaft pulled).
Anyway, that's how I understand the operation of the VC. And yes, with the drive shaft pulled the 80 won't move unless you lock the center diff. Mine didn't anyway....
OK, now that's just weird.
I was all set to come in here this morning and edit my post to say an FZJ will drive with the front driveshaft removed (and the center diff. open), because Beowulf said he did drive his that way for about a mile once.
These threads are fun/silly/annoying all at the same time. :lol:
Cheers,
Curtis
If the t-case has the VC in it you can drive the truck unlocked with one of the drive shafts removed but you will need to first create enough heat in the VC by having it slip first. In Doc's case if no matter how much or how long he tried to get the truck to move it didn't then he has a problem somewhere in the t-case.
I just read where Doc's truck is a 93 and I think the early ones might not have a VC in the t-case as not all of them had solid axles and ABS and rear disc brakes. Not 100% sure so maybe someone else can clarify.
Good point. I think there are definitely some early 93's with that configuration.
Note: By "solid axle" I assume you mean "full floating alxe"?
Curtis
Ive wondered if I should remove the VC in my '94, I do not have ABS or rear disc brakes, I was told by my old master tech that I had in old style TC, But I never did get which old style, That being 91-92 or 93-94.
I guess I better head out and see what the case says
I'll bet you don't have one (a VC).
So the following is correct, right?: No VC in the TC, TC says HF2A. VC in the TC, TC says HF2AV. (The following is per Slee's website.)
Where on the case is the #?
Curtis
I just went out and looked and also going by the FSM pictures of the HF2A/V It appears that I do not have a VC...
This could also have something to do with all the clunking I get .
So, I wonder if it would be more feasible to put hubs on the front, I have a CDL switch.
Thoughts?
Forgot I got the number off the back of the case 40208469 if that is of any help
Curtis
IIRC the VC case will be longer than the non-VC case. If you can't find the ID stamp you could probably get an answer by measuring your rear shaft.
Installed by you?
No, It was there when I bought the vehicle
CJF said:
Definitely. Hope you're getting used to it.
Yes, I just drive it a bit slower in the neighborhood.
Im still trying to figure out what I should do about a PT kit, I looked a t the Slee kit and it has a spool and a few other parts, This is what I am wondering about, What would I need for a PT kit? just the hubs? or would I need the spacers and spool? I just dont know :meh:
Thanks for the help however, Its amazing what you can learn, If you take the time to look and ask :cheers:
I just read where Doc's truck is a 93 and I think the early ones might not have a VC in the t-case as not all of them had full floating axles and ABS and rear disc brakes.
My experience went something like this:
Truck was up on a lift at the exhaust shop, Noticed the cracked yoke (I felt it go earlier that day) and decided to take the shaft off. Dropped the front DS, and then the tech tried to drive the truck off the lift. Put it in gear, reved the engine a few times "Hey, why is this thing not moving?".... I had him lock up the CDL and left it that way. So for those 5-10 seconds, the truck didn't move. I didn't attempt any type of long term no-CDL-driving tests.
not much of a test but you still might have a non VC t-case
