I think maybe we need to start a new thread on how differentials operate. I'm seeing some really surprising posts from folks that should know better.
Yes, you can drive your LC without a viscous coupler. Just don't loose traction to ANY wheel, or you'll be dead in the water. This is different than driving without a driveshaft (front OR rear) where you will need to LOCK the center diff to move at all. As long as you have the drive shafts in place the axles will turn without the VC. Power will be split equally until one wheel slips (ice, gravel, etc...) at that point all of the power (because the VC is removed) will go to the slipping wheel. Your truck will be no different than a 2 wheel drive car at this point. Then, you can lock your center diff, and it will be the same as most conventional 4WD vehicles, and power will be split (50/50) to both axles and you'll be able to move again, unless the other axle has a spinning wheel. I suppose at this point you could lock the axle lockers and have true 4WD- even on wet ice you should be able to move (slowly) at this point.
