I'm working on getting ready to sell my 97 Lexus LX450 with great bones and lots of work done. I just don't have all the pics and details yet, but let me know if you're serious. See images and description below.
FJ80 Lexus LX450 Triple Locked Toyota Landcruiser
$20k or a reasonable offer. Don’t waste time with unrealistic offers
1997 230K miles ?? Have to look to confirm the exact mileage
Engine 230K miles
New Radiator
Wits End Blue Fan Clutch upgrade
Ford Facing 90-degree oil filter adapter (M-6880-A50) Banjo bolt deburred & chamfered
New A/C Condenser, Accumulator, Evaporator core (A/C is ice cold)
Head gasket replaced by the previous owner
Wits End Oil Pump Leak kit (not installed yet)
Dual OEM cats removed and a single Magnaflow spun cat installed for clearance
Drivetrain less than 6000 miles on all components listed below
Front and rear axles fully rebuilt with new bearings, seals, and fluids
Birfields cleaned, inspected, and repacked with Red Line CV grease
Cruiser Outfitters Birfield knuckles rebuilt with all new felts, seals, rings
Front and rear brakes have new calipers, rotors, rear load-sensing proportioning valve
Replaced all questionable wheel studs and have spares studs and extractor tool
4:56 gear third members from East Coast Gear
New OEM Aisin E-Lockers assembly front and rear (still have originals)
Suspension
Old Man Emu Stock height full suspension kit +.75” lift with front 20mm spacers
OME springs, shocks, steering stabilizer
OME Caster Correction Bushing and tool (not installed)
33” - LT285/75R16 Falken Wildpeak AT3W (less than 5000 miles)
Exterior
Wits End Floppy Mirror fix driver & passenger sides, both power mirror work
Front bumper Rigid LED Daytime Running Lights (high, low, off function)
OEM roof rack removed to inspect for rusted nut zerts, all are OK
Have all components and hardware to reinstall the roof rack
OEM running boards removed and front OEM mud flaps installed
Spare tire leveling kit installed but not used, interior tire carrier holds the spare tire
Paint in decent to good condition, clear coat on the roof and PS fender need attention
Clearcoat pulled from the tape around Rigid DRL’s
Passenger rear plastic bumper corner kissed by parking lot driver
No rust on the body panel, underneath, or drain holes
The frame has only surface rust on factory welds and bolt heads
Front inner fender mounts have rust at single bolt mount (both sides)
Interior
All power windows and sunroof are fully operational
Front power seat Gamivi full gear sets and screw replaced and all fully functional
New leather-wrapped steering wheel and shifter handle
Wits End Useless Ashtray Switchplate with Ram X Mount for phone
All interior doors sprayed inside with sound deadener
Front driver and passenger new power window motors
Rear floor and cubbies have sound deadening matt installed
Rear third-row seats with like new leather, one seat removed and goes with the sale
Second-row seats very good leather with no tears
Driver and passenger seats reupholstered with vinyl by the previous owner :-(
Front, Rear, and Cargo area WeatherTech floor mats
The carpet is good/decent but has some improper cleaning spots
Kenwood 7” radio with Apple Carplay & Android Auto (still have original)
Head unit Hands-Free microphone hidden above mirror
Back-Up Camera with parking lines, OEM look, and mounting
Pioneer 6.5” door speakers with color-matched grills and 6” amplified Bazooka tube
Interior tire rack has mount bracket for CO2 10lb or 15lb PowerTank
PowerTank bracket doubles as Bazooka tube mount (single connector removal for CO2)
Original owners manual and binder & original Lexus Emergency kit
One OEM door remote and alarm key fob
Miscellaneous
OEM service manual, Axle nut socket, wheel stud removal tool, original speaker grills
Spare wheel Center Caps
Have to also inventory spare items I have this weekend
Any original parts removed or replaced if not damaged
Quote Reply
Report Edit
@97BigPig
