VIN Plate
Wyoming
I'm looking to buy a 40 with a clean title. Problem is the VIN plate is gone, but the frame # on the tag matches the last 5 digits of the VIN on the title. The number on the frame has been obscured by a welded on bumper as well.
Where can I get a new vin tag made?
Little confusing. Last five numbers on what tag? Are you saying there is a tag on the license plate? Says no VIN plate and covered on the frame by a welded on bumper. So nothing on the vehicle itself with a VIN you can read? Pre 81 with the short VIN easy to mix things up and get away with it. Seventeen digit on the 81 and later not as easy. How much the cruiser cost would decide if I bought a one I couldn't see the VIN on the frame.
There is a tag on the inside of the front passenger fender with the frame number on it. That number is the last 5 digits of the VIN, which is on the title. In short, the last 5 on the title match the frame number.
It's a '67 with the powertrain removed, but included. Asking 6k for it.
@WyoRancher
Check out SOR.com. The plate you have may be the only one supplied for that vintage FJ40.
"Early USA models had only one ID tag located on the firewall. VIN can also be located on the left frame rail in front of the tire."
So your saying you can see the last five digits of the VIN on the frame? Not clear since you said tag. It not a tag on the frame but rather stamped right into the metal. If you have the last five digits of the frame visible and they are stamped seriously doubt it is not the original frame. The passenger fender plaque is the only other place that will have the VIN on a 67. 3/69 was the start of the A pillar plaque. Always find it funny when someone with a early 40 says all matching numbers. The only other place than the frame with the VIN was a plaque held on with screws. Mid sixties until 3/69 the VIN was only on the frame and right fender. No place did the tub have any type of ID number.
So there is a tag under the hood with the "frame number" and engine info on it.
There is a number on the frame too, but it's been messed up.
There's a title with the full VIN, last 5 digits of which match the "frame number" on the tag under the hood, but the number on the actual frame cannot be read.
In pictures I was sent, the tag on the pillar is plainly missing.
The 40 was originally blue, now black, and the tag was obviously there whenever it was painted.
I dont think your interior pic is from a 1967 FJ40. The steering column is wrong. Be careful, the frame # may have been altered or destroyed, to hide its real vin #.
We probably need to see more pics of the 40, inside and out, to help determine the year. Some states go by the # stamped in the frame and others don't.
With that door and that steering column production date would be 9/72-12/74. Which would either be a 73 or 74 model. A pillar clearly removed and no number on the frame that could be read all you have is a plaque under the hood held on by screws. Unscrew that plaque and could be anything. The A pillar plaque was held on by rivets that had to be drilled out to remove the plaque, why? Sounds a little fishy to me.
Is the hood missing the holes for the rubber bumpers and windshield hooks? If so, that would be an LV hood. The missing A pillar VIN tag and you stating the frame horn VIN number has been removed would lead me to suspect the worst about the history of this truck.
What do you mean by LV hood?
Yeah, the guy showed me the frame around where that number should be, whoever put that bumper on did a pretty terrible job.
@WyoRancher
So, have you looked at the SOR link I posted regarding VIN plates? If so, then a 1967 model year wouldn't have the plate on the passenger fender.
The pictures illustrate a mongrel FJ40. Early fuel tank sitting on the driver's seat, later model steering column and padded dash, etc. don't support a 67 model.
What does the title have for a VIN? Have you referenced it to the VIN date list on the SOR website? If the VIN is for a later model than 1967 and the title is for 1967, you can figure out for yourself that there's a major problem.
I'm saying a 73 with a few other parts. Someone could have removed the hood pads and hooks. Missing corner footman loops on the barn doors and footman loops in the rear corners were on 72-74. If the heater switch or switches have fan front and fan back that would be a 73. Check in the wheel wells for roll bar supports for a 74 (9/73-12/74).
@WyoRancher
I looked briefly, but have been driving. I have time to sit and look at it now. I'll get back to you, thanks.
I can't find
@WyoRancher
@WyoRancher
Is there a VIN number lookup to find years? Sounds like it's about a '73, but the title says '67. According to the SOR link is probably about '73 as well.
I can't find
The same SOR link I sent, above. You'll see a button to identify month and year of the frame number. Frame and VIN we're identical back then.
Excellent, found that! According to that chart, this cruiser is from March of '67.
Another interesting thing I found is that the frame tag on the fender is riveted on, not screwed on.
Long list of things that say it is not a 67. Padded dash started 9/67 and is a 68 model. But the 68 did not have that steering column. 9/67 the steering mounted by four studs on the bracket. Earlier was a clamp. If it doesn't have a clamp and VIN says earlier 9/67 the frame is not a 67. Obvious there is something fishy going on. Surprised you haven't decided to pass yet.
