It looks like you have about a 2* drive angle at the front u-joint. I think this is where your vibration is coming from. Even if you use a DC shaft it might not run smooth as that shaft wants 0*.
Since you have 3" drop brackets now the easiest way to correct this is to use the 4" drop brackets instead. They should reduce that drive angle to with in a DC shaft spec and add some caster that I'm sure you could use.
Basically a 4" solution which is where you are right now anyway.
