Very Basic Bulb Question
Marietta, GA
I have looked and cant believe how hard it is to find the answer (I don't trust the guy at the auto parts store). What bulb should I be running for front and rear turn signals om a '71 fj40? 1157?
Thanks
1157 is the winner!
That'a a duel element style 2amp bulb (when blinking). Should work perfectly.
1156 is a single element bulb. Your year cruiser has two functions in one bulb. Running, and blinking, hence the 2 elements. 1156 has just one, so no blinky...
And the amps are important to ensure the flasher works properly. Really cheap versions of these bulbs pull less amps, which can cause a no blink (constant on) situation. Sylvania is a trusted brand.
You could also go LED but then you would need a new (electronic) flasher that could handle LEDs.
