Valve spring pressure
Karis Finland
My 1974 F.5 has GM LS1 valves and springs installed. Looking at the F & 2F service manual both say 71lbs at installed height. Replace at 59lbs. Mine has 120lbs closed and 260 open with .090 coil bind clearance . Wonder if this will cause trouble.
change to standard sbc 305 springs if those LS valves will take them. I had plain old SBC valves installed on mine. you won't spin fast enough to need a lot of spring pressure. I'd see about going to a lower rated spring, myself
Rusty72, you are correct about the stock valve springs, rated at 59.5 to 71.6 lbs. We use to sell higher performance valve springs for our higher lift cams, they were infact 120 lbs, needed to prevent valve float when using higher lift cams. Also the springs you are using evidently coil bind at .090 travel, the ones we sold could compress .570 before coil bind. But now here's the bitch, the springs we sold are now Pioneer #053432700, BUT a minimum order is a 100 piece box at $1.44 each (per spring), so you'd need to get with some buddies and do a group buy to afford the $144.00 purchase.
Stock f and 2F valve springs take quite a bit of abuse before you experience valve float. I've hit 5K multiple times without issue.
To answer the question, the additional valve pressure has the possibility of wearing the cam faster. Just as Brian Noted..
The cam is a Delta 250S pretty much a stock grind. Will call Delta and see what they recommend. I should of said, with .090 clearance on the coil spring the open pressure is 260. I really think its too much pressure for such a stock low rpm engine. Would be a miracle if the engine ever gets to 5K the way I drive. Will do a bit of research for different beehive springs or install stock SBC if possible. Another options is to pull the head, install another set of new valves and springs. Has been too long since the machine shop rebuilt the head to take back. Then again I could install it as is. If the cam goes flat pull the gas tank and battery then haul it off for scrap. That's probably closer to reality than I want to admit.
