If you can turn a wrench get the following and get it ALL....I repeat get it ALL
3 Cans Brake Cleaner
Handful of Rags
Magnetic Nut and Bolt Holder (Harbor Freight has)
Hand Cleaner or thin gloves
1/4" Socket Wrench Set with Flex Head
3/8 Socket Wrench Set and Spark Plug Socket (rubber insert)
Needle Nose Pliers (to remove PCV Grommet)
Flat Razor blade (gasket remover)
Toyota Valve Cover Gasket
Metal Intake Gasket (Do not reuse old)
6 New Toyota Valve Cover Spark Plug Grommet Seals
6 New Toyota Spark Plugs (they are like $3 each)
Lisle Seal Puller ($10)
Toyota PCV Grommet ( Search Inshino OEM Honda/Acura Made in Japan PCV Valve Grommet on
Ebay)
Toyota PCV Valve (don't get any other brand)
Check the condition of the hose that is coming off top of Valve Cover; this is the PCV. If it has cracks in it when flexed go to Local store and get a piece of Gates hose that is oil compatible and 2 hose clamps for the ends. If in good shape reuse.
Remove the Intake Hose and be gentle with it as they like to crack
Clean it up with the brake cleaner and rags.
Remove the PCV Hose.
Remove the spark plug wire covers on Valve Cover and keep all wires in same location and flip whole assembly off to side still connected to distributor.
Put on the gloves
Remove all the little bolts in the Valve Cover.
Remove valve cover and any remaining gasket material
Flip Valve Cover over and remove spark plug grommets (using Lisle tool) and replace. Insert new one with something similar in size to grommet like a Lg Socket. Try to remove PCV Grommet and break grommet if it won't come out. Use Needlenose to fish pieces out. Install new Grommet and New PCV (positive Crankcase Ventilation).
Replace Plugs at this time.
Install new Valve Cover Gasket.
Set on motor and put in all bolts loosely. Start torquing in back and do opposite corners bolts.
