Valve cover leak
In my opinion it's a good time to do plugs, plug wires, plug tube seals, PCV and grommet, and cap & rotor. These are all "while you're in there" stuff. What you WILL need is a throttle body gasket as it is a one-time-use item. That said, lots of folks have reused it with no ill effects. I could never find a torque spec for the valve cover, but the consensus here is that it requires a light touch. Have fun
Thank you. I was planning on doing a tune up before I found the oil leak. I've ordered plugs, wires, distributor cap, rotor and phh work around kit. The phh kit should be here today. I don't think everything else has shipped yet I'll call and see if I can add the rest to the order.
I still have to clean everything off from below. I really hope I do not find anything else.
See if the bolts are loose first. Mine were finger loose when I got my 80. That being said, I still ended up changing out the VC gasket along with everything else above sans the cap and wires since they were previously done.
Well, if you take off the upper intake to clean everything up, then you get a bit better access to the top area of the hardline, other than that, the PHH will still be P. As per inkpot, you should change the bypass hose while you're in there since it can be quite P as well, be careful to *NOT* break the knock sensor near the PHH while working on things - many have broken that connector - be warned!! Not a bad idea to just remove it during the PHH job.
cheers,
george.
cheers,
george.
Thanks for the advice. I may just remove the sensor as long as the sensors not another pain to remove.
