valve adjustment
puyallup wa
i was gunna adjust my valves on my F motor and was using the write up from this web site but it wasnt to clear, and i think it was for a 2F motor, so i need some help. ive located the line and ball thing on the belhousing, and it said to line up the line for top dead center. when i did this it wasnt enough room to get correct size feeler gade in either side. im not sure if this was do to them being to tight, or if i hadnt rotated it as much as i should have or if it was on the wrong stroke or what. im stuck. can anyone explain to a newb how this is done properly.
Don't forget that there are two TDC positions in a single 4 stroke cycle. You may have been off by 180 degrees.
There is nothing magical in adjusting them at TDC. You can adjust any random valve at any time that the lifter is completely off the cam lobe, which is nearly 3/4 of the rotation of the cam. Just watch the valve until it comes up and stops, then rotate it a few more degrees and adjust it. That way you don't have to read any thing and worry about which valves you need to adjust when; you just watch them.
Get a discontinued Snap-on overhead valve adjustment tool from Ebay. Get a flexible LED light. Get a hand starter. Pull air cleaner and valve cover. Warm engine. Put it in neutral. Pull the number one plug. Use the under hood hand starter to bump the engine until TDC (hash not ball) mark lined up with fixed marker. Look in the number one plug hole with the flex LED; 50 percent chance you will see the top of the piston. If so, adjust the first set of valves as in "Valve Adjustment" article in tech. Put the plug back in, rewarm the engine (yes with the valve cover off), repeat above with the number 6 plug pulled and the second set of valves.
Thats my kind of wrenching. All of the boys around here would never go for that though.
Dude,
This is one of those things that's a lot easier to demonstrate than describe, but we're all trying.
Also, judging by your post, we need to go back to LC 101.
Disregard posts by DocB! You do not need any fancy discontinued Snap-On parts, remote starters or LED anythings. You need the crank handle that should have come with your rig. Things move slower with it, you know exactly where you are in crank rotation. Lacking that, you need a few feet of flat land to roll your 'Cruiser back and forth in gear to move the engine around.
You also need a manual. Many use a Haynes. You can buy one at the same place you would get a remote starter at. It's good enough to get you started (pun intended). You need to have that manual open and in front of you the first time you do your valves. I have adjusted my valves so many times that I no longer need the manual. You are not there yet.
If you get the TDC line at the pointer in the window, you are at TDC somewhere, either #1 or #6. The distributor and the valves should tell you which. If unsure, then pull the sparkplugs. You will visit both TDCs in your adjustment. You can start any time. If you can't get your feeler gauge in, and you're sure it's the right feeler and the right valve (you know intake from exhaust, right?) then use the endwrench and the screwdriver to make it fit in (just). Remember 1,2,3,5,7,9. Works frontways and back
thanks for all of your help, i think im a lot clearer on all of my questions, im gunna go ahead and adjust them now, and ill end up picking up a haynes manual too. thanks again everyone :cheers:
Pighead said:
Dude,
I just adjusted my valves yesterday using these tools (some recommended in Jim C's tech article) and it went smooth and fast. A remote starter is by far the easiest way to turn the engine till it reaches TDC. Also the fastest. A cheap LED light is the easiest way to peer at the top of piston one or six to see which is at TDC. The discontinued Snap on valve tool is by far the easiest way to adjust the valves and not accidentally tighten the valve more while tightening the lock nut (that's what the tool is made for). No, these tools are not required; but they make the job easier. There are multiple ways to do this job, all having some aspects in common. Just because Pighead has never used these tools does not mean they are not helpful. Maybe if he has "adjusted his valves so many times he no longer needs the manual", he's adjusting them wrong. He has "because I have never done it it is wrong" syndrome.
Gosh, DocB, I never meant no disrespect. Sure those are nice tools to have and use ('cept maybe the remote starter, never found a need for it).
But the Dude's gotta learn to walk before he can run. We're babysteppin' here.
I'm not gonna confuse him with the easiest fastest way, Dude's gotta do it the slow tedious way so he can appreciate the fast easy way later. And understand what he's doing.
There are indeed numerous ways to adjust valves, many of them well documented and discussed thouroughly in the archives here. I'm sure not gonna argue with how you do yours. Whatever floats your flotilla...
The factory engine manual, and even that hanes diaper cover this topic...
Shortly after acquiring your truck, maintenance and repair literature should be purchased. This, along with many other simple and daunting tasks are covered in depth in these reference materials, and will prove worth their weight in precious metals many times over. So that when the need or desire to work on your vehicle arises, you have these right in front of you, in the garage, opposed to waiting for someone to answer your inquiry out here.
But agian....that is just me.
Good luck!
-Steve
Pighead, you mentioned something about a crank handle. When I got my 40, it did not come with it, but when pulling the engine for the restoration, I noticed the provision for a crank handle and realized that I got gipped. Where can I get one?
Hmmm...Look in parts for sale?
https://forum.ih8mud.com/showthread.php?t=40266
Or ask anybody who's done a V-8 conversion?
Pigs have a place for carrying a handle, under the rear seat...find a Pig in a junkyard, look under the rear seat.
Maybe SOR, MAF, any of the vendors here who have a bunch of 'Cruiser parts lying around?
Handy to have. Good luck.
I have the hand starter, and it is very useful, but..... I like the easy method of putting truck in 4th gear, removing all plugs and pushing it a few feet to slowly sneak up on the tdc marks. And, the ball is 7 deg BTDC, some flywheels have a line for TDC, not all.
I got the crank and handle on my 60 but it hits the radiator when I stick it in the hole on the front valence. Thought someone told me even with the stock radiator it interferes. :doh:
staplebus wrote: when i did this it wasnt enough room to get correct size feeler gade in either side.
Make sure you are measuring the correct side of the rocker arm. The side you adjust with a flat-head screwdriver is not the same side where you insert the feeler gauge.
