- Thread starter
- #21
Totally agree! Thanks for your help!And FYI Mike you are leaps and bounds from where you were a few months (or weeks) ago when we talked. Regardless of the backstop, high five man!
Understandably. Booster plays a pretty big role in vacuum tho. So an easy thing to rule out. Granted I've never had one go so if it does maybe loosing the brake pedal is more likely than having it be too hard to push.Thank you! I have to think it is related to something i've done recently with the truck but maybe not.
Yep.... that's the video at idle after the valve adjustment and before I put everything back together. The only thing that happened between this video and the vacuum leak was putting it all back together and tightening the EGR pipe coming on the manifold.Is that video at idle?
That's good to know. Thank you. I didn't remove that J pipe. Just tightened the bolts down on it which I thought could have triggered something with the EGR.The only part of the EGR system that could cause a vacuum leak is the EGR valve not fully seating. Everything before the valve is positive exhaust pressure. If the EGR J pipe that bolts to the manifold was removed, (as an example) the noise from the exhaust would be loud as heck but there wouldn't be a vacuum leak.
