Valve adjustment question
Time for you to do some research then.
Valve lash can and does change from bench to block.
Eh, I agree with pin_head. I doubt the small amount of warping or anticlastic deformation matters for the 1fz
:popcorn:
I was thinking I'd get my measurements with the head on and cams in place, take my cams off after that because I want to take off the head to have a look at the cylinder walls, and I'd be able to get at the shims easier in the process. I've never done this, do I still need to depress the "unit" even with the cams off to get the shim off of there, or does it just lift right off? Thanks for the comments thus far .
