Vacuum shifter?
Roseville
What is everyones take on the vacuum shifter over the manual shifter? I am looking to purchase a '70 FJ40 with a vacuum shifter and want to know if this is going to have to be replaced with a manual set-up. Currently it is working fine, do these typically hold up well or are they total headaches?
Thanks for the input
Fman
I've wheeled mine for several years without a problem. Some folks have had issues with them and others have not. It's as personal preference as anything IMO.
I'd do a search on "vacuum shifter" I know this has been discussed a few times.
If you get get rid of it keep me mind....I'll take it off your hands ;)
Welcome.
Corrosion inside the acctuator on the tcase is about the only thing that has ever given me any problems. Clean it out, and they are good to go. Some have had issues with dry rotted old hose, or rusted tubes that can create vaccum leaks. Having this type of 4wd acctuation would not prevent me from being interested in a truck...
Good luck!
-Steve
Mine still has the Vacuum. Works great and gives me the option of 2 wd low for putting along, also shifts on the fly very easy.
I also have it. Like it a lot for the 2wd low and the shift on the fly. Never had problem with it. Even in winter. If the cruiser is good ,go for it. A vacuum shifter in not a problem. Good luck :beer:
I have it in 2 45's(and a fj62 actaully), I like it, never any issues, I have OEM rebuild kits for the thingy on the firewall and the other thingy, but havent needed them. Plus its cool...:)
Running the vacuum shift for close to 20 years now without complaint. Several guys I know have LOTS of complaints with the NOISE of the floorshifter. I thought about a floorshift when I first got my cruiser, but knowing what I know now, I am SO GLAD I didn't change it.
Mmm. Vacuum good. My diaphragm came filled with water, and the first winter it froze. One of the first fun jobs was to get under there and drain it out in the cold. Not a problem since.
Replaced mine with mechanical on my 71 and switched to twin stick shift setup. I like it, works for me. Seemed like a lot less crap to go wrong, ya know?
I have the vacuum and wouldn't change it, but twice now I've pulled the cable out of the switching valve on the firewall. It breaks off just inside the valve. 2 weeks ago, I broke it going into 4wd, and was able to push the cable back in to disengage, but then I had to finish the trail in 2wd unless I wanted to crawl underneath and switch the vacuum hoses or disco the hoses and switch it manually - but it could be done if necessary.
Wow didn't know there were so many fellow vacuum shifters out there, and I didn't know you can shift on the fly with that..can you do it at any speed or is it like below 15mph or something. Also I am gonna switch out to a 4spd tranny and trasfer case can I attach the vaccum shifter to the 4 speed or is it just for 3spd set ups? Thanks Chuck
Mine will do it at any speed. Also make sure the indicator light works. this way you know it is engaged.
yup, any speed(that a cruiser can do) make sure your hubs at locked though ;)
not a bad anti theft feature either, how many punks would figure out the dash lever is in neutral or how to shift a 3 on the tree? ;)
Quick question about the vacuum shifter.
So this past weekend I went through my tranny and t-case because everything was leaking and turned out a bunch of stuff was loose, I feel lucky I didn't have a big boom in there the week earlier.
Anyhow, I opened up my vacuum shifter, the box that contains the lever that transmits from the diaphragm to the shift fork, and the thing was completely full of gear oil. I looked in the FSM and it didn't show that an o-ring was supposed to be there so I didn't screw with it, however I did drain the old oil, it seems like there should be a little in there but full? Should I fill it back up from the bleeder hole? Or will it pump itself as full as necessary?
I just thought that was strange
Wow, did I miss something? Mine's dry. It was dry when I tore it down for rebuild with no sign of having oil in there...didn't read anything in the manuals about oil in there unless I just missed it??
Yeah I looked through the FSM and it didn't say anything, but like I said earlier there isn't an oil ring on the shift fork shaft so oil could very well get in there. I have never had a problem with my vacuum shifter working. I'm courious. I mean, it was topped off.
Mine usually has some lube in it but not that full. Was the tranny low? Maybe a bad seal draining the tranny into the xfer????
I can't seem to keep a front output seal in my xfer. Leaks bad and the last seal (new OEM) lasted a couple months. Gotta fix that this week.
