Vacuum shifter?
both were low, generally the transfer will pump oil into the tranny when the seal between them is bad.
Do you know about the trick where you use a hose to connect the two drain plugs so that your oil re-circulates between the tranny and the t-case? I'll prolly do this one of these days so I don't have to worry about that POS seal anymore, even though I just put a new one in.
Hey Busta, you got any pics of that hose trick that's pretty cool!
Also can you use a vacuum shifter on a 4spd?
Thanks, Chuck
Unfortunately I don't have any pictures of it because I haven’t done it yet, but you just find fittings that match your fill plugs and run a hose between them, routing the hose below the fill plugs so gravity lets it work. I haven’t sourced fittings but I'm pretty sure I have also seen a person drill and tap is fill plug and thread X fitting into it.
I don't see why you couldn't use a vacuum shifter on a 4speed, I know that the nose cones are interchangeable, i'm pretty sure the shifting mechanisms are as well.
