vaccum line help
Is there any way to desmog my fj40?
I have a 77 fj40 from california and it's equipped with all the smog goodies. But they are all getting old and falling apart. I've replave a lot of the little hose conecters with pieces from fish tank plumbing( all the little t's and y's), but it's all getting old. I live in washington and it's a rig i use for play, is there any way to get rid of all the smog and emission stuff.
thnks
Have you seen the tech links in this site? Look in the menu at the top of each page http://www.ih8mud.com/cruisertech.php
There's a little bit of help there. Generally you can't just start dismantling the smog equipment and expect the engine to run well. People do it but those who do it successfully start with a good understanding of how that stuff works and interacts.
Just plug the vacuum lines for the EGR and the vacuum retard line tot he distributor so that the EGR stays closed and the timing won't retard. This will give you the most bang for our buck.
If you feel the need to save another 0.5 hp, you can gut the air pump and remove the air rail and plug the holes, but I don't think it is worth the effort.
Don't remove the throttle positioner or power piston vacuum lines that go to the carb or the VSV that operates them or it will run worse and get worse mileage.
Whatever course you take DO NOT DISCARD any of the bits you take off. A lot of that old emissions stuff is discontinued and is very difficult to come by. If you take it off and toss it you will be very sad one day when you want a piece of it back.
