Vac transfer case module, oil?
Texas
Should there be oil in the vac transfer case module assembly? In the FSM there is no mention of it and other that the ‘breather’ port, I don’t see a fill location.
I see a felt dust seal but I can’t find mention of it being filled with oil.
Hooter
Yep, it is open to the front extension housing, which is open directly to the transfer-case oil, this is how those parts get lubricated.
There’s a felt dust seal and a rubber o-ring on the piston that moves the shift fork, so there’s not suppose to be oil in that cavity (the upper piston is what the diaphragm pushes and it’s also sealed). The shift fork is lubricated by gear oil in the front drive extension, These internal mechanisms should have good light grease on the joints and the pistons. There is an oil port on the top of the vacuum housing that’s for squirting a little light oil to lube the diaphragm piston where the detent is and the associated ball bearing rides as part of the vacuum light switch system.
I see the dust felt seal but I don’t see an o ring.
After 40 yrs, I guess the dust felt is so incompetent that it allows oil to flow by.
I can’t figure out any other way it can get in.
Yeah my bad, there’s not an o-ring, just the felt seal. It gets cleaned and reoiled. Probably ok for TC gear oil to migrate in there, but not necessary. Here’s coolerman’s rebuild info - Rebuilding the 3 sp T-case: Reassembly Page 2.
Oil migrates. Clean it out and seal it back up. Check it in five years. As long as the rubber seals hold vacuum, the system is virtually bulletproof. Usually the cables seize/brake long before the actuators fail.
