V8 conversion
Sounds like you got the hard part but have stumbled on the details.
Your question is extremely vague. If you mean the stock gauge, get an adapter from Advance Adapters/Downey/other to thread your Toy temp sending unit into the Chev head. there is a plug on both heads..use the one you want.
If you are talking about an aftermarket gauge simply screw it's sending unit into one of the head locations. The coolness factor raises exponentially if you do both. many consider the stock gauge to be little more than an idiot light.
Check out the pics in my sig line for some ideas on where to mount extra gauges.
...then get an adapter and screw it in. The kits I have bought in the past from AA & Downey have both included this water temp adapter as well as one for the oil pressure sending unit. Maybe they're purchased separately now or you got your stuff somewhere else??????????????
See: http://www.downeyoff-road.com/Catalog/index.htm
look for part number 15609 temp adapter @ $10.17.
I would go aftermarket. Summit makes a 4-in-1 tach with electronic temp, oil, and volts all built into the face. It's about $120. The white face looks kinda riced out, but I think it's available in a black. Just figured I'd throw the suggestion out there.
Carbed engine, or Fuel injection, they changed the size of the thread in the head.. its now smaller..
for an older engine buy the adapter and use the Stock sender unit.. for the newer head, thread it into the head and it will , but its a different thread...
the adapter is already on the 2F head it will thread into an older carbed chevy head . if you still have the 2f .f might be the same ??
found info from an older thread
just bought one from toyota for 2f .this also fits the chev v8 head like $6 bucks
toy part #90404-16160
TEMPERATURE SENDING UNION
1/75-7/80 FJ40/55
