- Joined
- Feb 2, 2004
- Threads
- 115
- Messages
- 327
I am having some trouble reinstalling the timing belt after a head gasket installation. I have the shop manual and have tried following the procedure but cant get the marks to line up. I have the solid mark on the timing belt lined up with the mark on the crank gear. The engine is at TDC on the compression stroke. The shop manual says to run the belt around the water pump pulley and then run it toward the drivers side cam pulley. Next turn the driver camshaft pulley clockwise slightly and then install the belt so the mark on the belt lines up with the camshaft alignment mark. I cannot get this part to work. It almost seems as if the belt is too tight. This is the belt that was originally on the engine so I know it fits. I've tried different combinations of changing crank alignment and the camshaft pulley alignment and I am always off by on or two teeth on the cam pulley. If anyone has better way that works please let me know.
Thanks,
Joe
Thanks,
Joe
