my montero has rear shackles very similar to the 1st generation toyota front shackles, with the offset because the frame is wider than the spring eyelet. I have lift shackles that I want to use on my montero, but they are not offset, could I just stack some washers on either side of the spring eyelet to compensate for the difference in width? Is this a terribly unsafe idea? I don't see how the strength is compromised at all, but then again, what do I know...
what do you all think? thanks!
Better safe than sorry!
