Used Engine -- How to Assess?
I just purchased a '68 FJ40 for parts. It is a total rust bucket but I have a feeling that the engine has very few miles on it. It still had the smog pump, original oil lines, cannister oil filter ... These sorts of things would have been replaced if the cruiser was run very much. My quandry is that the engine has not run in many years and has no starter. Therefore, I have no way of telling whether it is worth my time and effort to pull the engine. The engine does turn freely whey you put a wrench on the crank.
I will pull the head next week and just want some opinion as to whether and try and pull the short block as well. A full pull of the engine+tranny+transfer is out of the question as this thing is out in the woods and I am doing this by myself.
Whaddya think?
Look at all the fluids as well, check the color of the anti-freeze, look for metal shavings in the oil pan, etc.
Pull the head look to see if there is any rust on the underside of the head, look at the cylander walls, fell them too. I got 69 rust bucket, for the frame as it turned out the axles and the motor were well worth the purchace price of a couple of pounds of steak.
Lex
Starter is long gone and there is no wiring to the ignition. So, no compression test. Coolant was bright green. Did not check the oil but the end of the dissy that goes down into the oil pan was clean and no corrosion. I'll pull the spark plugs next week to see what they look like.
This thing even has the original stickers on the air cleaner and valve cover. Rare to see an old cruser that still has them. On the other hand, the bottom of the cruiser is total rust. I am thinking it was a dedicated snow plow rig (but I'm in Georgia so maybe not).
How is it that a 68 has a smog pump?
You could pull the plugs and spin the engine with a hand crank (or socket on the crankshaft pulley nut, or a pipe wrench).
15-20 times round with the throttle plate open and you'd have your compression numbers.
For that matter, even if you can't spin it, you'd still know something.
1968 (some titled in '69) was a wierd year. Air pump showed up and then went away for 5+ years. Last year for the 1 BBL carb. Here is a picture of the only '68 I have ever seen with a smog pump in place. Mine had the air rails but the pump was long gone. The factory literature from that year shows it as well.
EDIT: Actually, as I look at the picture, the air pump is gone on this one too. They have looped the air rail hose back onto itself so the hose goes from the air filter around in a circle to the air pump. The old cruiser I am parting even has the vacuum actuated valve to turn the air pump on and off. Think anyone needs it?
Can you really get compression number spinning an engine by hand? Sounds like a "candid camera" moment waiting to happen.
I didn't know about the '68 pump!
I don't know why you wouldn't be able to get compression by hand. Why would the engine care what you are using to spin it?
It seems like your valves would be open for a very long time cranking by hand and you wouldn't get as much compression as you would with a starter. If a starter and battery were available to you, I'd try to hookem up and fire it. Just spray out the carb and see what happens. Heck, if it does start, it sure will make extracting it from where it is alot easier.
You cannot spin it fast enough by hand to get an accurate compression test. I second Pin Head. Put a starter on it, wire up the ignition system, and start it. You can do a compression test at that time as well if you feel the need.
Well, just for grins, I tried this tonight on my F135 engine. And you're right, without a hand crank bracket and with only one arm I couldn't do it. But I think someone without spindly toothpick arms could do it with the right setup using both hands: I was close.
:D
:D
Please tell me you took some video.
Sorry, no video. Not enough hands :D
Don't tell me you guys have never seen a hand crank used?
