After searching for a few months, I found a new to me 80 series! Thanks a ton to @Gwagg and @cruisermatt for the inspection. I knew ahead of time this was going to be a project, however it's also my daily driver. My plan is to make sure the mechanicals are sound and I've baselined the vehicle before I press forward with cosmetic or suspension upgrades.
Once the vehicle came off the truck, I immediately noticed the driver sideview mirror was loose. A quick search on the forum and the two zip tie method had it fixed. I've since ordered some various parts to get her baselined, including the "middle section" of the stock air intake. Several of you pointed out it was not OEM and I don't like the way the intake is currently set up.
"As-Is" from the Previous Owner:
I took the time today to degrease the undercarriage with Simple Green and then coat with Fluid Film. Overall, the undercarriage looks great for a 19 year old vehicle, but living < 3 miles from the coast I know I need some extra protection!
After Fluid Film applied:
I also took the time to remove the running boards, I think it really cleans up the look:
When I drove the Cruiser to work yesterday, I noticed a CEL. I went to have the code read today and it showed a PO402. I found a blocked tube as described in the following thread. I believe I'll need to order a gasket to remove the throttle body, as well as research the FSM for the proper way to get 'er done.
Last but not least, I replaced the standard reverse lights with LED's for improved visibility. I went with the following from Amazon. Time will tell if they're sufficient.
Nice job on the belly...listen to Beno, he knows his s***e!
