This could be a long one.
My CEL came on shortly after purchasing my rig last spring. We were in the middle of moving, so I just lived with the annoying light until this fall.
I started researching on MUD and came to the conclusion that most folks get rid of the code by replacing the EGR modulator. Did I mention that this is also the easiest part of the EGR system to replace, maybe w/ the exception of the EGR Temp Sensor? I contacted CDan and received the part in a few days. The light was off for about a week, and came back on.
I still had not ordered my FSM, so it was back to the "search" function. After reading many threads, it appeared that the next culprit must be the VSV valve. I also concluded that replacing the VSV valve was something that I really didn't want to do myself. I took the truck into the local dealer and asked them to double check the code and tell me what they thought. They confirmed that it was a P0402 code. The technician wanted to isolate the problem so they blocked the tubing from the EGR valve to VSV with a BB. This was the second time that I had heard of this method (first time was here on MUD). Well, the CEL came back on.
Now I'm a little concerned so I go ahead and order the FSM. I read through the EGR section, and still end up thinking that I don't want to mess with changing the VSV. I was a little intimidated by the steps to remove the valve for replacement/testing.
So, I find a Toyota specialist here in Southern MD and explain to them what I've done. They checked the truck out and said that they normally replace the VSV, EGR valve, EGR Mod, and Temp Sensor to correct an EGR malfunction. I scratched my head and told them that the reason that I brought the truck to a specialist is so that I wouldn't waste anymore money swapping parts...I could have done that. I asked them to start w/ the VSV...light comes back on.
I take it back to them, and ask if they had checked the vacuum lines etc... YES.
I give in and tell them to replace the EGR valve as I had already cleaned the Temp Sensor per the FSM and MUD. Guess what? Light comes back on.
I take it back and they replace the Temp Sensor, and clean everything up again for me. Guess what? Light comes back on!
I take it back and they check it out again and told me that there was a loose. I pick up the truck for the xxxth time, and the light came back on yesterday before I got out of the parking lot at home.
I went back to the shop and was as polite as I could possibly be. They explained the troubleshooting process as they saw it, and I explained my version of isolation and tracking down the problem to a specific component. I left with the diagnosis that I needed a new ECM.
So, this morning I'm bound and determined to fix the darn thing myself. I got the FSM back out and reread the theory of operation and then crawled back into the engine compartment.
Guess what I found in the first 15 minutes? The tube that runs through the intake between the EGR valve and the VSV was TOTALLY blocked. It was tough getting the hoses off to check, but I definitely have flow now.
If I understand correctly the VSV will shut off the EGR at a given time based on ....... If this vacuum line is clogged...... the EGR will not shut off, and could result in an excess flow error code.
I'm off now to test drive the truck and run the logic test. I'm not sure if it will cure the problem, but I can at least tell you not to start swapping parts without first checking the simple stuff.
Let me test it and I'll get back to you. Thanks again for all of the awesome input here on MUD...next time maybe I'll pay closer attention to the details.
