- Thread starter
- #41
Thanks Brian!
IdahoDoug said:If idle output is the issue, be sure you're going to actually improve that over stock. Some aftermarket makers advertise a big output, but you only get it at higher RPMs and it may be that at idle there's no difference from stock.
DougM
bjowett said:Belt length will work, but a little longer might be easier for R&Ring things.
Bruneti said:If the Tundra pully ends up being slightly smaller, it could be used instead of a longer belt to address this concern. This would also spin it faster for more amps at idle.
:shotts:bjowett said:If I had more time, I'd produce some brackets for others so they may use the Tundra HO alternator....
