Unknown Oil Leak
Tennessee
New to the site, but have been reading posts for months now. Just bought my first 97 LC and stoked! Problem is I have a serious oil leak. A quart every 25 miles. Previsiouly thought it was a rear main seal, but decreased and steam cleaned it and the leak is coming from below the air intake manifold. All the wires are oily, but due to lack of space I can't locat the exact spot. Is there a typical place around there that leaks. Apparently the valve cover was replaced by previous owner.
About the only thing I can think of that would be behind the intake is the valve cover gasket. If someone has replaced it recently, I think I'd be checking there.
A valve cover gasket isn't super hard, and while you're doing it, replace the spark plug tube seals and the PCV grommet.
Welcome to 'Mud! :flipoff2: I hope you like it here!
Your oil filter is right there, maybe it's just not screwed down tight enough.
Oil filter is tight and not leaking. Valve cover seams to not be leaking either. Is there an oil line under the intake that could be leaking?
Where is that?
Behind the A/C compressor. Passenger front. Probably not your leak.
A quart in 25 is a LOT. It could very well be your oil filter seal has a chunk of dirt and is spraying a fine stream toward the intake. Bright flashlight and take look while it's running.
There are no other oil lines in that area. Way up front you have your distributor o-ring where it goes into the engine. Very common leak, but not under much pressure so it usually drips real slow.
Have seen the old oil filter o-ring stick to the block, then when the new filter is run, the old o-ring blow out, causing a big leak. Or,, if the valve cover gasket was changed, may have slipped out of place, out of the groove when installed, this would cause a big leak.
Valve cover it was!! Thanks for all the helps guys! Will probably need a lot more in the near future
