Unbelievably tenacious code 71. Any ideas?
Alpine, UT
Well, I'm stumped with this blasted code 71 I've been trying to fix for some time.
Here's what I've replaced:
  • Modulator
  • VSV
  • EGR temp sensor
Here's what I've done:
  • replaced vacuum lines
  • cleaned that little tube that goes through the plenum
  • tested the EGR valve (yes, it makes the engine stumble/stall when vacuum is applied at idle)
  • cleaned the throttle body, including the port that goes to the egr valve
Guys, I've searched and researched and I'm out of ideas. My only thought is that the egr valve is old and the vacuum that I'm applying for the EGR test is stronger that what the system is.
Any ideas? Please help!
94 Cruiser, 166,000 miles
2 Thoughts :
If you have read thru these threads , including the P0401 ones ( the OBDII equivalent to our code 91 ) AND THERE ARE LOTS OF THEM ! :D then somewhere in this mad mob was something that told me the vaccuum source was supplied thru or by (?) a port out of the charcoal cannister.
I have a PM into Cruiser Dan - curious to see how much this rascal is ( the cannister).
I had a '79 T/A that suffered thru some weird issues caused by a bad charcoal cannister, which is why I have latched onto this thought.
Who knows ? :confused:
My other thought was the gas cap as on my rig it seems that almost every time I gas up I get the light for a while afterwards, but it is gone by 7/8 tank.
Last time I filled up, it seemed like it really "sighed" when opened ( vented pressure ) , and the light DID NOT come on that tank.
Maybe it is somehow back pressuring the cannister , then the EGR ?
Those are my thoughts - far better minds than mine have tried to resolve this issue - as evidenced by the threads in the linky - so best of luck to you with this issue. :flipoff2:
Britt
Yep, I clear the codes every time. The CEL comes on right after two drive cycles, no delay, nothing. So the problem must be fairly big to trigger it that quick.
I know this sounds simple but our system relies heavily on vacuum which includes tightening your gas cap. Leaks will throw codes.
Check your fuel cap rubber gasket and really tighten it if in doubt. You should get a hissing(sucking) everytime you fill the tank.
Check your vacuum lines after replacing air and oil filters.
A quick but sometimes dangerous method of testing for leaks involves spraying WD-40 along your vacuum lines, intake hose, pcv and any other suspect,if the engine surges(WD-40 is flammable) you have found your leak. Propane and a small hose will also perform well and better pinpoint your problem.
Do not spray your hot manifold and please only do this outside. Better yet start while the engine is cold...
