U Joint Replacement?
Chicago
I have had a vibration under my 2004 GX for a little bit now. Replaced one wheel bearing, didn't fix it. I know another wheel bearing needs replaced also as there is play in the wheel when I jacked it up.
However, I started hearing a squeak in reverse today. Looked it up and all I could find was 100 series U Joint squeaking in reverse. Would this apply to the GX as well?
Also, if it is the U Joint, would I need to replace the U Joint or just grease it as many of the 100 series owners have done?
Very possible. 05+ for an updated part for the driveshaft. I bought new on my 03 to get it. Gets rid of the thunk too and isn't that expensive (under $400).
