tyre wear
lebanon,pa
Website
www.facebook.com
i'm getting real bad wear patterns on my front tire(no s).
77 40, 33X9.50 bfg at's something around 32-34 psi.
the right side is wearing bad on just the outside 1/3 of the tire(can post a pic in a bit). the left is wearing just fine:confused:
the truck also has a pull to the right.
i just crawled under it and did a quick tape measure toe-in check.
i'm getting about a 1/2-5/8" difference front to rear, with the rear wider than the front for a "//___\\ condition.
is my toe in that bad? i thought i read somewhere that 1/4" was close enough. or do i have something bent somewhere? though i don't see anything out of the normal.
Underinflation, out of balance, bent rim, worn tie rod end, bad/loose wheel bearing could also cause that tire wear. You do have more toe-in than you need, and that can cause excessive tire wear.
Pulling to the side is often underinflation or a dragging brake, but again, bad bearings, bent spindle, knuckle arm, as well as alignment issues are concerns.
