I've got two questions:
1. my steering is really squirrely right now. So much as driving across a white painted line causes issue. Might be a coincidence, but I almost immediately noticed the 'squirreliness' after I replaced ONE 295/75/16 BFG mud, mounted to the rear driver side, while still running the three other much older (same size, mileage, and model) BFG muds that I'd imagine have upwards of 3/4" to 1" smaller overall diameter due to wear. Could it be out-of-alignment front tires fighting to be in control of the direction I wanna go? I will get the tires rotated this weekend and see if the problem persists. But don't want to get four new tires until I figure out what size I should get.
2. I've recently replaced tired 2" lift OME shocks, front panhard bushings, front swaybar bushings, front and rear brakes, and rear upper control arm bushings. After that, I got to realizing that sooner or later ALL rubber/bushings are going to need replacement. HERE'S THE QUESTION: should I replace with Toyota OEM? Or should I go with aftermarket upgrades for my upcoming motor mounts, tranny mounts, rear lower arms, front trailing arms, and rear swaybar? It's my daily driver and I 'wheel' occasionally on outback AZ terrain.
3. Bonus question: The mechanic I use might be a bit of a hack. About 30% of the time, I'm wasting time going back to have him tweak/finish/correct work I previous paid for. Can anyone message me any Phoenix-local mechanic recomendations?
Thanks for reading!
C
Thanks for reading!
C
