Hey All, I am tracking down some wiring gremlins in my '77 FJ40. The turn signals were working, then my wife slammed the passenger door and they stopped working (strange but true!).
1. Battery is fully charged (on battery tender most of time)
2. Hazard lights work.
3. Side lights work.
4. Brake lights work.
I have removed all the rear light clusters and cleaned all of the ground points to bare metal, cleaned the bulb seats.
I have removed the Hazard switch and cleaned the contacts in the wide connector.
I have removed the turn signal switch and cleaned and sanded the contacts.
I have jumped the front left turn signal bulb housing metal to a chassis ground to test the ground.
I can hear the flasher relay click when the turn signals are working.
I have changed the turn signal fuse out.
I am down to 3 possible situations
a. Flasher relay is broken and works with hazard but not turn signals.
b. Turn signal switch is broken.
c. voltage not getting to turn signal switch.
Does anyone have any other thoughts or other things to try?
Thanks!
Thanks!
