Turn Signal Issue
the controllers that I have seen plugged into the factory harness. There was a spot in the harness that allowed you to unplug two connectors and then plug the controller into them. So to remove the controller all you had to do is unplug the controller and then plug those two connectors back into each other. You'll have to look and figure out how that controller was installed. Take more pictures of the wires where they connect if if you have to and I'm sure we can figure it out.
If you don't tow then you don't need to replace it as the stock system will work fine. However I have a Hoppy controller in mine and it was bought at NAPA and plugs in as I've mentioned. You might go and see if the local store has one so you have an idea of what I'm talking about.
Here are a couple pictures showing how the wires go into the box. It seams like it is all one part. There is no way to 'pull" out any type of a plug from the unit itself. It's all self contained. Maybe came from the factory like that??
follow the wires that come out of the box to where they attach to the factory harness. That thing in your hand is not a factory part, it's been cut into the factory harness some where and that is where you need to look in determining how to remove it.
The wire on the side that says "to car" are the ones you want to follow.
I tracked the wires back to where they split off from the trucks original wiring set. It looks like they used some type of little blue splitter that clamps down in the wire, has a little metal spacer which channels the current to the new wire(attached to the trailer module). I removed the wires that headed to the trailer box. I cut the ground wire off. (Very tricky spot to unscrew) and disconnected the green wire that runs over to the DS under the carpet. After doing all this I now have NO lights in the rear. (Turn, break, night time lights) Is there something else I need to do?
Check that wiring again. Probably the ground since you have no rear lights. Those "blue splitter" things are called Scotch Locks. They were derived by the illegitimate son of the devil and old lady Lucas. It is very possible that the wires were severed where those connectors were used. Happens routinely.
-B-
Agrrrr. So after removing the box this afternoon I was going to run to the store for supplies. The truck won't come out of park! Could this all be related b/c it seams like I can't press the break far enough down to allow it to go into drive. Like I said before NO lights are working in the back.
Thanks all.
