Tuff Stuff Winch
Has anyone used a different roller fairlead from the warn on the ARB and have it fit without modification?
Dorm room? Yeah, fabbing stuff is probably not in the rules:lol: And it's a project that will require more than a Leatherman:smokin:
I actually installed the roller fairlead that came with the Smittybilt first. Had to drill the holes right but just didn't like the look. It was at that point I figured out the the need to use the Warn fairlead to tie the upper lip in. Here's what it looks like, tucked up against the bottom of the upper lip.
Could you use a winch plate bolted or welded to the ARB front bumper to install the winch upright so the feet arent first and it sits like the winch is supposed to? I understand the bumper is built in with a winch plate, i would just rather the winch sit upright
I have had one of their earlier versions for the past 3 years with no problems because we don't see much water out here. I have used it a lot to pull out stumps and brush, but I have used it a few times on vehicles too.
TuffStuff are generic Chinese winches with the parts that interchange with most other Chinese winches of the same style.
The importer/vendor is only a few miles from me, so I bought locally in case I had any warranty issues. They have been pretty decent with me, but I haven't had any problems for them either.
It is the later "waterproof" or water resistant model that has the waterproof Albright knock off contactor. This is a bonus as the older solenoids are unreliable.
You could, I suppose, but extra work, weight, cost...
BTW, pretty sure the plate that Harbor Freight sells is virtually the same, but IIRC cheaper and, if a HF is nearby, no freight cost.
If people want to know more about waterproofing one of the T-Maxx clones like my Smittybilt and most other Chinese planetary drive winches, I wrote up my approach to this in this thread: https://forum.ih8mud.com/threads/waterproofing-a-winch.371911/
Thanks for the info. I was just curious if it would work. Would rather the winch face the right way
Well, engineering wise, feet first makes a lot of sense. They are strongest like that, although I don;t pretend to be an engineer. AFAIK, there's nothing wrong with however you mount it. Check the manual, though, but IIRC it's cool either way. A man's gotta do what a man's gotta do and all that. I'm pretty sure the ARB is up to dealing with the winch feet first, but nothing wrong with tying to the frame rails with your mount -- except the longer bolts can be surprisingly pricey because they're some special finethread. Don't order a box of 25 if you only need 8 or whatever. I didn't shop around, just went to Fastenal, but at least they usually get things right and quick so there you go.
:hmm: Well, it WAS a thread about some technical winch mounting advice for the 80. We could make it it a thread about your brand insecurities if you want...:hillbilly:
Or you can find a much better write up here https://forum.ih8mud.com/threads/hf-badlands-12-k-diy-winch-hack-waterproof-upgrade-mod.848498/ ;) I believe the Tuff Stuff is the exact same as an Badlands 12k.
Darn, if I'd known there was going to be a quiz in the morning, I would've studied. I skipped the long line for "Competing for Much Better" or "best" -- all I can offer is my experience. I'm sure you have great thread...too.:D
