Does anyone have any experience with the winches made by tuff stuff, Im thinking about ordering this one. Also does anyone know how the mount up to the ARB bumper, if spacers or any modification in needed. Thanks for the help in advance.
No direct experience, looks like the typical cloned winch for the Chinese mothership except for cosmetics. The 12k versions are typically the widest. You'll need spacers. 1/4" and 1/2" mild steel bar stock works well, You want something wide enough to support the entire casting here it would butt up against the inside of the bumper. The spacers go between the winch feet and the inside of the bumper. They push the winch back to gain clearance so that the ends of the winch don't hit the inside of the bumper before the mounts are tightened. Without the spacers you could break the castings as you tighten the winch mounting bolts. My Smittybilt needed about 3/4" to clear the ends inside the bumper. It's a pretty simply exercise once you've sized up the situation.
Then there's the fairlead. The bumper comes drilled and set up for the Warm roller fairlead. You can drill some more holes and mount the fairlead that comes with the winch. However, if you look at the ARB, you'll see a big fat lip across the top of the bumper. You take the pins out of the Warn fairlead and they slip right in. This adds mechanical strength to keep the winch solidly mount when doing off center pulls, etc. IMO, if you try to save dollars by using the supplied fairlead -- if there's a roller option, then set it to up so its pins can slip through those holes.
Looks like you get a hawse style fairlead, so go ahead and buy the Warn fairlead if you were going in that direction. It is a little more (~$100) but makes for a neat clean bolon solution. A roller fairlead is really practical and gives a lot more flexibility. I don't know what experience people have had mixing 12k winches with fairleads.
When I bought my cruiser last spring the PO included an Engo E10000 winch with synthetic new in the box. One word- "junk". I go out quit a bit during the winter here in the sierra's and actually used this winch. After several pulls it's bound up inside and the rope is snagged on a set screw for the brake that is installed through the the side of the drum. I know this because I did some research and then called Engo. This set screw backed out then the internal brake fell apart and bound up the winch. When it did work it sounded like there were rocks in the gear box. I bought a lightly used Warn HS9500i on CL for $450. Has 125 feet of spotless wire rope and a line speed second only to the venerable 8274. It sounds like a sewing machine compared to that Chinese crap and the quality of the power cables and such is far superior. Maybe I got lucky finding an older 2004 model) "made in the USA" warn winch that someone only used a few times. I know most people on MUD will use a winch very rarely but it took less than a dozen pulls until I had a problem with my Hecho En Chino winch. How can they sell a winch with synthetic line for under $500? A replacement line on most any website is $200 alone. My 2 cents.
Most synthetic line is UV protected. I like it because it's lighter and can easily be repaired trail side if you know the weaving/siding technique. What I consider a disadvantage of synthetic line is that it is easily abraded on the granite that is so prevalent where I wheel. However, I have not broken a synthetic line yet. This warn I picked up on CL has the original like new cable (wire rope) still on it so I will use just use it with a blanket or jacket over it for safety. I have a problem spending $1200-$1400 on a winch too that's why I shopped For a lightly used winch. Not even Warn builds all there winches in the USA anymore.Yeah, I overlooked the synth line in making my comments, but it was late, very late.The hawse that's supplied is the cheapest alternative there, too. But I believe you can get roller fairleads for synth IIRC. The drawbacks and advantages are pretty much the same with the hawse or rollers, but you do need a roller fairlead that is made for synth. I suspect you may have to relocate holes to mount the hawse on the ARB, but don't know.
Synth is really great stuff, but must be handled carefully. Another factor is UV, so parking it in the blazing sun every day will likely shorten its life.
How do they do it that cheap? Who knows. I suspect those selling synth at $200 a line are probably making a tidy profit, so there's probably a lot less difference in cost vs cable at the wholesale level.
I have an ARB with a 12K Badlands winch installed just like @greentruck explained. I used 1/2" stock to make the spacers & re-drilled the fairlead that came with the winch to fit the bumper. Pretty easy install.
@wemahfouz save yourself the time and trouble and just buy these spacers http://www.amazon.com/Rugged-Ridge-11540-15-Mounting-Spacer/dp/B00390RLLY/?tag=ihco-20 . I am running them on my ARB with 12k Badlands and they are nicer then anything most people are going to make at home. They are 3/4'' thickness and 4.5" on center spacing of the holes. If you go to the winching and recovery forum you will find a lot more info on these topics.
My home brew spacers are just like these. Probably would have bought these had I known they were available & didn't already have the steel.
