Trunk won’t pop
NJ
I looked all over the web for this and I can’t find any info. I guess the only way to open the rear trunk is the rear button but it won’t work. I can open it manually if I climb through the backseats. Is there a fuse for this or is there any way I can troubleshoot this problem? Thanks
I have a 2008 LC
I have a 2008 LC
Have you had the battery disconnected?
If the truck loses power with hatch open you’ll need to reinitialize. Just close the hatch and disconnect battery for a min. When you reconnect it will reinitialize.
I have a 2008 LC
How do you open manually from the inside ?
To open the door manually you will need to pop the small plastic cover panel in the trim (center of the door) and manually flick a small lever switch - use a screw driver - you may need to remove a small plastic cap on the lock mechanism too.
Good to know. Thank you
