Troubleshooting Squeaky Brakes
Santa Cruz Mtns
Developed a squeak in the brakes... from what I can tell its the driver side only. Im running OEM calipers and 100 series pads. It seemed to have started after multiple river crossings (probably 15-20 total)
After I drive for about 10mins I start to hear a squeak. The noise is not static... it happens as if there is only one "squeaky spot" on one part of the rotor (imagine a pie cut into 8 pieces and only one piece is bad).
When I engage the brakes (even ever so lightly)... the noise will stop. Let off the brakes and it starts again. The noise seems to go away over 35-40 but I doubt it...I probably just cant hear it. Periodically, I will come to a long slow stop and the brakes will squeak consistently.
Took it to a shop and they said the rotors are ok. They didn’t see anything visually. There is no oscillation in the pedal. I double checked the life of the pads by peeking in the back of the rotor... they looked like they had plenty of life. Used some air to thoroughly clean out all the brake dust. Noise still occurs.
Next step... I was wondering if I can switch the pads from driver side caliper to passenger side caliper. If the squeak travels with it... then its the pads. Is this okay to do?
Any help is appreciated. I am trying to troubleshoot this without just throwing money at it (searching right now to see how much new 100 series pads are).
Issue with the pads? Dirty rotor?
EDIT: I was just reading about "anti-squeal shims"... could it be that this shim was removed to fit them in there? Maybe the pad has worn a bit and a small gap has formed creating a squeal???
Brake squeal is from high frequency brake pad vibration which anti-squeal shims mitigate. I have 100 series pads and occasional brake squeal. Once they wear in a bit, I'm going to install the anti-squeal shims.
You can swap your pads. You may want to move the wear indicator. I can't remember if this a removable item or not. It is on some pads.
Thanks for the info... I was planning to pull them tonight and at least inspect them. I will check for the pad (assuming I know what Im looking for). Can you buy these shims from the parts store?
Brake squeal is from high frequency brake pad vibration which anti-squeal shims mitigate. ...
X2, also some silicone grease (sometimes sold as brake grease) on the metal backing pad edges where they contact the caliper will solve it. Don't need much, just a skin and never get it on the friction material.
I replaced my front pads awhile back with OEM pads and noticed the PO installed some generic pads and there were no anti squeal shims in. I was going to buy some from the dealer but decided to try the brake grease first. I just put some brake grease on the back of the pads and haven't had any issues of squeal/squeak.
If you do replace the pads, make sure you bed the brakes in.
Salue
x2, they also have some goo made for the back of the calipers that dries to a rubbery finish to prevent squeaking. While you are in there, make sure all the rubber boots are in good shape, and use "brake lube" on the sliding pins and any moving parts (obviously, no lube on friction surface or rotor). Unless you have actually worn the pads to the metal backing plate, the squeaking is just from vibration and there is no functional problem with the brakes, just an audible annoyance.
if you are running on 100series pads, the shims to prevent squeals was removed to give room for bigger 100 series pads. put a set back in when the pads have thinned down enough...or silicon grease will do
Thanks for the info guys... I will get some tonight and grease up the components (will do both sides for good measure)
:beer: :cheers:
