My '94 land cruiser (366k miles) has developed a misfire that comes and goes. Its like a on/off switch is thrown between modes. The cruiser always starts quickly, and when not misfiring , idles and accelerates smoothly. When misfiring it runs rough at idle and has a significant loss of power and vibrates when accelerating. I used a laser temperature gauge on the exhaust manifold and found that the cylinder closest to the firewall is the culprit. When not misfiring, all 6 ports heat up evenly, but when misfiring that one cylinder doesn't heat up. I pulled the spark plug and it had some carbon build up, but not horrible. However, I found that the plug wire insulation was cracked and a piece of the rubber was broken loose at the end nearest where it connects with the plug. I replaced all the plugs and plug wires with new OEM parts. It ran fine. I drove about 50 miles (cruiser ran great) and thought problem solved. Nope, I stopped for a few minutes and upon restarting the missing returned.
I've read many threads already, but not sure what's next. I could guess and throw new parts at the problem, but I'm betting y'all will point me to diagnostic techniques that isolate actual source of failure.
Thanks
Thanks
